[mapguide-users] Not correct work Tomcat
Alain Lebatard
alain.lebatard at autodesk.com
Wed Apr 12 17:00:17 EDT 2006
http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp is not a valid
URL. /mapguide/mapviewerajax does not represent a folder, but represent
the AJAX viewer main script. If you look in the httpd.conf file of
Apache bundled with MapGuide, you should see this line:
Redirect /mapguide/mapviewerajax/
http://<YourHostAddress>/mapguide/mapviewerjava/ajaxviewer.jsp
So when you invoke
http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp, you are
actually invoking
http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp/bufferui.jsp
which is not valid.
Your first call http://localhost:8008/mapguide/mapviewerjava/fake.jsp
was the correct one. If you get a 404 error, it's certainly because
there is no file fake.jsp in
/usr/local/mapguideopensource/webserverextensions/www/mapviewerjava
The compilation errors are probably occurring because the jar file that
contains the API classes (such as MgException) could not be loaded. Make
sure that there is file named MapGuideApi.jar in the folder
/usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib If
the file is not there then this is a build issue.
Alain
-----Original Message-----
From: Safonov Alexey [mailto:alex-saf at archit.vrn.ru]
Sent: Wednesday, April 12, 2006 10:15 AM
Subject: [mapguide-users] Not correct work Tomcat
Dear colleagues!
I have collected mapguide-1.0.0 on a platform linux. Except for most
mapguide I have established LinuxApt with Tomcat. At testing it was
found
out, that on inquiry
http://localhost:8008/mapguide/mapviewerjava/bufferui.jsp the answer
turns
out:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented
it
from fulfilling this request.
exception
org.apache.jasper.JasperException: Unable to compile class for JSP
An error occurred at line: 25 in the jsp file: /mapviewerjava/common.jsp
Generated servlet error:
MgException cannot be resolved to a type
MapGuideJavaApi cannot be resolved
An error occurred at line: 34 in the jsp file:
MgLocalizer cannot be resolved
Though the inquiry http://localhost:8008/mapguide/mapviewerjava/fake.jsp
gives out " 404 error ", as well as is written in a management. The
inquiry
http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp is not carried
out
at all as the catalogue
/usr/local/mapguideopensource/webserverextensions/www/mapviewerajax does
not
exist at all.
How to me to achieve correct work Tomcat?
I use the distributive Linux Fedore Core 4 with the kernel
2.6.15-1.1833-FC4 and gcc-4.0.2-8.fc4.
Please, help me in solving this problem.
Best regards,
Safonov Alexey
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060412/71c83335/attachment.html
More information about the Mapguide_users
