[mapguide-users] Raster issues
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Apr 13 11:00:52 EDT 2006
Ah, I have noticed problem with loading multiple MrSIDs. Specifically,
it won't do it. You can select as many as you'd like to load, but it
will only actually load one of them. No errors, it just doesn't do the
others. No big deal though, because you can just load them individually.
Berdel, Brian wrote:
> Actually I was loading multiple Tiffs at one time, seems ok If I load
> one at a time.
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Thursday, April 13, 2006 10:47 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Raster issues
> Works fine for me with MrSID files. Haven't treid any other types yet.
> Andrew
> I am able to load raster files into studio, but when I try to preview
> the map it gives repeated errors and the only way out of it is to end
> the studio.exe process... anyone else experiencing this?
> *From:* Marko Podgoršek [mailto:Marko.Podgorsek at kaliopasi
> <mailto:Marko.Podgorsek at kaliopa.si>]
> *Sent:* Thursday, April 13, 2006 3:51 AM
> *To:* users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
> *Subject:* [mapguide-users] performance problems
> Hi!
> I installed mapguide server and and mapguide web server extensions on
> Win2000 SP4 (IIS 5.0).
> When I tested the dotnetviewersample with Sheboygan.mgp the
> performance of the server is very slow.
> The ajax viewer shows the map, the dwf viewer doesn't even load the map.
> Still, the ajax viewer is very slow, it takes about 1 minute or
> more to load the map at
> http://localhost/mapguide/dotnetviewersample/ajaxviewersample.aspx
> The dwf viewer stops at cca. 90% if you look at the progress bar at
> the top left corner.
> I used the IIS Configuration type on install.
> What's wrong?
> Marko Podgoršek
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.506-453-1025
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> /_Important notice to recipients_//_ - April 13, 2006_/
> Copies of documents that may be relied upon by you are limited to the
> printed copies (also known as 'hard copies') that are signed and
> sealed by the Engineer and/or Land Surveyor. Files in electronic
> formats, or other types of information furnished by the Engineer
> and/or Land Surveyor to you such as text, data or graphics are for
> your convenience only. Any conclusions or information obtained or
> derived from such electronic files will be at the user's sole risk.
> When transferring documents in electronic formats, the Engineer and/or
> Land Surveyor makes no representation as to long-term compatibility,
> usability, or readability of the documents resulting from the use of
> software application packages, operating systems or computer hardware
> differing from those used by McMahon Associates, Inc. at the beginning
> of the project.
*Andrew DeMerchant*
ph.506-453-1025
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
