[mapguide-users] performance problems
Marko Podgoršek
Marko.Podgorsek at kaliopa.si
Fri Apr 14 05:57:11 EDT 2006
Good day Marko.
Could you provide more details please?
For example:
- the type and number of processors
- the MGHz of the system
- the amount of RAM the system has
- are there any other applications or web applications on the server
- are you running Studio on the same machine or a separate client
If the dwf viewer is stopping it's possible the system is timing out which is a symptom of the performance issue.
One possibility is that if you don't have enough physical memory the system is swapping to virtual memory.
Regards,
Dave Wilson
Hi:
I'm using 2.4GHz P4 with 1GB of ram. It's a test computer (my work computer).
There are no other web apps on the computer. I'm not running Studio. I just want to try out the sample map (Sheboygan.mgp)
I found out why is it working so slow. PANDA ANTIVIRUS. Don't use it :)
Now it's fast.
But still...Dwf viewer still stops at about 90%. Why is that?
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.4.1/311 - Release Date: 13.4.2006
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060414/1f91e9fa/attachment.html
More information about the Mapguide_users
