[mapguide-users] Tiled map using GETMAPIMAGE
Paul Spencer
pspencer at dmsolutions.ca
Wed Apr 19 13:19:58 EDT 2006
The mapagent has a GETTILEIMAGE. I'd try using that :)
Cheers
Paul
On 19-Apr-06, at 1:16 PM, velen wrote:
> Hello,
> We were able to generate tiled map using GETMAPIMAGE from a .net
> windows form; below is the screen shot. As you can see, in the
> sampleSheboygan map, some “District” numbers were chopped off in
> the same tile or showed in the adjacent tiles. I understood this is
> probably because each tile get rendered individually, but is there
> a solution for making tiles look likes what ajaxviewer does?
> Thanks for your help in advance,
> Velen
> <image001.gif>
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
More information about the Mapguide_users
