[mapguide-users] RE: ODBC problem...
Dave Wilson
dave.wilson at autodesk.com
Wed Apr 19 14:13:57 EDT 2006
One of the features of having the join on the ODBC resource is that you
could chain multiple Attribute tables together if you needed to rather
than combining the data in a table or view. Of course the more you chain
together the slower your performance will likely be.
Chaining the spatial to spatial or attribute to spatial doesn't make
sense for the most part I agree although you could join an SDF to an SHP
to get attributes if you really didn't want to merge the data, but I'm
not sure how likely that case would be. Of course I could argue then I
have a POINT source in ODBC and join it to an SHP for attrbutes, but
again would you really want to do it?
I think the options are there for flexibility.
Dave
_____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, April 19, 2006 12:06 PM
Subject: RE: [mapguide-users] RE: ODBC problem...
Thanks for the clarification Dave. I hadn't even looked at my spatial
datasource to notice that there is now a Join portion of the dialog at
that level. I was thinking the join was only defined from the tabular
datasource. Now that I have set it up there (pretty much using the same
steps I previously outlined) it is working fine. I can display my
parcel polygons with tooltips and properties derived from the secondary
Access database.
It is a little confusing that it can be done the other way around and
that a layer can be seemingly created from that while choosing the
geometry feature from the secondary datasource. That process should
probably be changed in Studio to prevent that from happening.
I'm still having problems with point data from an ODBC resource, but
will do some more experimenting later.
Andy
_____
From: Dave Wilson [mailto:dave.wilson at autodesk.com]
Sent: Wednesday, April 19, 2006 7:26 AM
Am I correct in understanding you are using the spatial resource as the
Secondary resource? The Spatial resource needs to be the primary
resource if this is what the layer is to be based on. The join is
generally for attaching attribute data to spatial data such as adding
properties from an Access table to an SDF.
Point data from an ODBC resource should also work as a primary resource.
Dave Wilson
_____
Sent: Tuesday, April 18, 2006 6:22 PM
Here are the steps I took to create the join. Note that I wasn't able
to do with anything with the join in terms of creating a layer from it,
however.
* Once your datasource is setup and you can see the tables listed
in the Refine Data Setup area, click the New Extended Feature Class
button.
* Choose your other datasource in the repository that you are
connecting to
* Choose the Primary Feature class (table)
* Click on your New Join below the Extension you just created
* You will most likely only have one option for the Secondary
class (table)
* Select your Primary Column and Secondary Column fields. These
are the key fields tying together your primary (tabular) and secondary
(spatial) datasources.
If you get this far, please let us know if you can successfully create a
layer where you can view the resultant objects. I also tried creating a
layer from X and Y points in a table from this database and, again, was
not able to view the resultant geometry.
Andy Morsell
-----Original Message-----
From: Thud732 [mailto:devlin.fung at sapience360.com
<mailto:devlin.fung at sapience360.com> ]
Sent: Tuesday, April 18, 2006 4:30 PM
Subject: [mapguide-users] RE: ODBC problem...
Hi Andy:
Can you please outline your 'join connection' steps? I was able to
establish a successful test connection, but failed when joining.
Thank you.
TC
View this message in context:
http://www.nabble.com/Failed-to-test-the-Web-Server-Extensions-after-ins
tallation-t1432431.html#a3978903
<http://www.nabble.com/Failed-to-test-the-Web-Server-Extensions-after-in
stallation-t1432431.html#a3978903>
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060419/7dcce487/attachment.html
More information about the Mapguide_users
