[mapguide-users] can u tell me please how can i create the .mwf file?
shailesh shailesh at simplexindia.com
Fri Apr 21 08:37:06 EDT 2006
hi Sukalyan
I guess you have messed up with posting  your query .. replied to query and posted MWF query in MGOS  anyways
 if you are talking a MWF file , As far as i know MWF was suppoerted by earlier  versions  rather  I don't think it is a prat of open source
now if you want to create MWF file you can use MG author 6.5 u can use shp or sdf files for creating maps
you can find tutorials/pdf for the same on mapguide site
-shailesh
Original Message:
From: sukalyan chakraborty <chakraborty.sarkar at gmail.com>
Date: Friday, April 21 2006 04:26 PM
Subject: Re: [mapguide-users] problems with invoke URL
 On 4/20/06, shailesh <shailesh at simplexindia.com> wrote:hi all.
i have a problem with invoke url command, when i assign the URL TO OPEN
..\dotnetviewersample\navigatetask.aspx
it shows me page cannot be dispalyed
however when i type
http:\\localhost\mapguide\dotnetviewersample\navigatetask.aspx
in URL TO OPEN it works
i also tried something like c:\1.html after creating a file in C:\ even that does not work
and also when i tested my application whihc is on the webserver
it tried typing the URL to invoke
http:\\myipaddress\mapguide\dotnetviewersample\navigatetask.aspx i was unable to get
(i tried this because the localhost path was working onmy local machine)
need help on the correct way to write the URL to Invoke "
thanks
--------------------------------------------------------------------- To unsubscribe, e-mail:
users-unsubscribe at mapguide.osgeo.org For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
