[mapguide-users] problems with invoke URL
Butler, Juan P
jpbutler at co.pinellas.fl.us
Fri Apr 21 10:11:38 EDT 2006
Are you using Mapguide 6.5? Not sure why you would be posting here for
.mwf file. The new Mapguide Open Source no longer uses this format.
If you are using Mapguide 6.5, just use Mapguide Author.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: Friday, April 21, 2006 6:57 AM
Subject: Re: [mapguide-users] problems with invoke URL
can u tell me please how can i create the .mwf file?
On 4/20/06, shailesh <shailesh at simplexindia.com> wrote:
hi all.
i have a problem with invoke url command, when i assign the URL TO OPEN
..\dotnetviewersample\navigatetask.aspx
it shows me page cannot be dispalyed
however when i type
http:\\localhost\mapguide\dotnetviewersample\navigatetask.aspx
in URL TO OPEN it works
i also tried something like c:\1.html after creating a file in C:\ even
that does not work
and also when i tested my application whihc is on the webserver
it tried typing the URL to invoke
http:\\myipaddress\mapguide\dotnetviewersample\navigatetask.aspx i was
unable to get
(i tried this because the localhost path was working onmy local machine)
need help on the correct way to write the URL to Invoke "
thanks
--------------------------------------------------------------------- To
unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060421/afb9a3fa/attachment.html
More information about the Mapguide_users
