[mapguide-users] Access database - Studio 2007 preview
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Fri Apr 21 12:19:46 EDT 2006
I'm referring to one that I posted about maybe a week ago.....I can't
get any ODBC datasource to actually work in Studio....I see the
datasources fine, but never see a list of table / fields, and when I
test my connection, it fails. The concensus seemed to be that it was the
Studio Preview, because someone else did the exact same steps, and it
worked....the only difference was our Studio versions (his was the full).
Andrew
Butler, Juan P wrote:
> Andrew,
> Which ODBC problem are you referring to? The two issues that I
> brought up yesterday were the highlighting of a selection doesn't work
> on a joined layer and the refresh issue. Are these what you are
> referring to?
> - Juan
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Friday, April 21, 2006 9:45 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] Access database - Studio 2007 preview
> I'm using Studio 2007 (preview) v1.0.0.16802.....Is the ODBC problem
> to do with this version of Studio, or the OSGeo FDO Provider for ODBC?
> I've got a project that I need to get done in 1 month, and am trying
> to figure out if it's going to happen or not. With my current setup, I
> can't get any of my Access ODBC datasources to work....no one has
> suggested a workaround as of yet, so I'm starting to think that it's
> just not going to happen. Does the solution have to come from Autodesk
> (a new Studio version), or OSGeo (a new Provider? I would tend to
> think that Autodesk would be slower than OSGeo, so that's why I'm
> wondering.....Thanks.
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.506-453-1025
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
*Andrew DeMerchant*
ph.506-453-1025
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
