[mapguide-users] problems with invoke URL
Butler, Juan P jpbutler at co.pinellas.fl.us
Sat Apr 22 15:55:00 EDT 2006
I think you are confused.   We are testing Mapguide Open Source which is a totally different version than Mapguide 6.x.   You should put the new version of Open Source on a machine that doesn't have previous versions of Mapguide.   You will need to download Mapguide Studio for your "map authoring" and data loads.
Also, the .NET version of the Open Source install requires .NET framework 2.0.  This is the reson for your error.
- Juan
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: Sat 4/22/2006 1:06 AM
Subject: Re: [mapguide-users] problems with invoke URL
yes i'm using mapguide 6.5
when i attempt to run it from
http://localhost/mapguide/mapviewernet/ajaxviewerabout.aspx then get the error
Compilation Error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could not be found (are you missing a using directive or an assembly reference?)
Source Error:
Line 21: <%@ Import Namespace="System.Web" %>
Line 22: <%@ Import Namespace="System.Globalization" %>
Line 23: <%@ Import Namespace="OSGeo.MapGuide" %>
Line 24:
Line 25: <!-- #Include File="common.aspx -->
Source File: C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\ajaxviewerabout.aspx    Line: 23
On 4/21/06, Butler, Juan P <jpbutler at co.pinellas.fl.us> wrote:
	Are you using Mapguide 6.5?   Not sure why you would be posting here for .mwf file.   The new Mapguide Open Source no longer uses this format.
	If you are using Mapguide 6.5, just use Mapguide Author.
	Juan Butler - Senior Programmer/Analyst
	GIS Applications
	Pinellas County Information Systems
	jpbutler at pinellascounty.org
	From: sukalyan chakraborty [mailto: chakraborty.sarkar at gmail.com]
	Sent: Friday, April 21, 2006 6:57 AM
	can u tell me please how can i create the .mwf file?
	On 4/20/06, shailesh < shailesh at simplexindia.com <mailto:shailesh at simplexindia.com> > wrote:
	hi all.
	i have a problem with invoke url command, when i assign the URL TO OPEN
	..\dotnetviewersample\navigatetask.aspx
	it shows me page cannot be dispalyed
	however when i type
	http:\\localhost\mapguide\dotnetviewersample\navigatetask.aspx
	in URL TO OPEN it works
	i also tried something like c:\1.html after creating a file in C:\ even that does not work
	and also when i tested my application whihc is on the webserver
	it tried typing the URL to invoke
	http:\\myipaddress\mapguide\dotnetviewersample\navigatetask.aspx i was unable to get
	(i tried this because the localhost path was working onmy local machine)
	need help on the correct way to write the URL to Invoke "
	thanks
	--------------------------------------------------------------------- To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060422/61307105/attachment.html
More information about the Mapguide_users mailing list
