[mapguide-users] Slow performance + crash...
Traian Stanev
traian.stanev at autodesk.com
Tue Apr 25 10:42:07 EDT 2006
Did you try turning off the Access layer to see what the performance
would be without it?
_____
Sent: Tuesday, April 25, 2006 10:33 AM
Subject: [mapguide-users] Slow performance + crash...
I've started on migrating a Mapguide 6.5 file to a Mapguide Open Source
map. But the performance isn't very good. It takes more then 10 seconds
to load the map, and zooming in on an area also takes about 10+ seconds.
In MG6.5 this is about 2 seconds, which is acceptable.
Here is the link to the MGOS version:
http://mapserver.gisnet.nl/sites/viewer/index.php?mapname=gestel
Here is a link to a similar mg65 version:
http://www.gisnet.nl/sintmichielsgestel
Also, the service stops a lot of times. Maybe this is because the text
object are loaded from an access database with the FDO provider?
Willem
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060425/e17024e1/attachment.html
More information about the Mapguide_users
