[mapguide-users] Slow performance + crash...
"Antonio Lucas Rodríguez (sr&tec)"
alucas at srtec.com
Tue Apr 25 10:58:04 EDT 2006
Willem Schwarte wrote:
> I've started on migrating a Mapguide 6.5 file to a Mapguide Open
> Source map. But the performance isn't very good. It takes more then 10
> seconds to load the map, and zooming in on an area also takes about
> 10+ seconds. In MG6.5 this is about 2 seconds, which is acceptable.
> Here is the link to the MGOS version:
> http://mapserver.gisnet.nl/sites/viewer/index.php?mapname=gestel
> Here is a link to a similar mg65 version:
> http://www.gisnet.nl/sintmichielsgestel
> Also, the service stops a lot of times. Maybe this is because the text
> object are loaded from an access database with the FDO provider?
> Willem
I've the same problem. Mapguide OS is more slow than Mapguide 6.5.
Antonio Lucas
Software Engineer
alucas at srtec.com <mailto:alucas at srtec.com> www.srtec.com
<http://www.srtec.com>
963·959·513
Fax 963·731·756
SER&TEC
avda. Ausias March 79 - 1
46013 Valencia
Skipped content of type multipart/related
More information about the Mapguide_users
