PHP -> .NET Active Selection
kalpesh kalpesh at pie-solution.com
Wed Apr 26 05:53:42 EDT 2006
Any progress to this one. I tried exactly what you specified in your first
post using .NET. The problem is after the XML is passed to the other page
and then when we try and do
MgMap map = new MgMap();
map.Open(resourceService, "wise");
MgSelection selection = new MgSelection(map);
if (selText != null && selText.Length > 0)
    selection.FromXml(selText); //It fails here
It now tells me "Attempted to read or write protected memory. This is often
an indication that other memory is corrupt."
The selText is the XML that is submitted by
window.opener.mapFrame.GetSelectionXML() from some other page.
View this message in context: http://www.nabble.com/RE%3A-PHP--%3E-.NET-Active-Selection-t1476910.html#a4098462
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users mailing list
