Problems with ODBC Connection to Foxpro database
Chris White
chris.white at keytraffic.com
Wed Apr 26 11:38:59 EDT 2006
I'm attempting to establish a connection to a Foxpro database using
Autodesk MapGuide Studio.
I've created a system dsn and created connection with Studio however
when I press test connection I get the following error:
System.Net.WebException: The remote server returned an error: (559)
MgFdoException.
at
Autodesk.MapGuide.Studio.Site.Comm.RequestManager.ExecutePendingGetReque
stToString(Operation operation)
at
Autodesk.MapGuide.Studio.Site.Comm.RequestManager.TestConnection(String
resourceId, String provider, String connectionString)
at Autodesk.MapGuide.Studio.Site.FeatureSourceInfo.TestConnection()
at
Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.TestConnectionControl.b
uttonTestConnection_Click(Object sender, EventArgs e)
After reading other posts on this matter I logged onto the mapagent and
used the TestConnection functionality:- This time I get the following
error:
An exception occurred in FDO component. RDBMS:
An exception occurred in FDO component. RDBMS: Exception occurred in
method MgFdoConnectionManager.Open at line 840 in file
c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.c
pp
Any ideas?
Thanks
Chris
Chris White
Software Architect
Key Traffic Systems Ltd.
Ardencroft Court
Ardens Grafton
Alcester
Warwickshire
B49 6DP
Main: +44(0)8451 303040
Fax: +44(0)8451 303141
Mailto: chris.white at keytraffic.com
<mailto:%20chris.white at keytraffic.com>
Web: www.keytraffic.com <http://www.keytraffic.com/>
This e-mail & any attachments are intended only for the use of the
person(s) to whom it is addressed. It may contain information that is
privileged and confidential within the meaning of applicable law. If you
are not the intended recipient, please contact the sender as soon as
possible by return mail or Tel +44 (0) 8451 303040. The views expressed
in this communication may not necessarily be the views held by Key
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060426/2ef5063f/attachment.html
More information about the Mapguide_users
