[mapguide-users] RE: PHP -> .NET Active Selection
Kori Maleski km at pat.ca
Wed Apr 26 13:35:07 EDT 2006
Pass the Selection/Session to an aspx page using Invoke URL or Script.
Or use the GetSelectionXML() in your own clientside javascript - posting it to your page.
For example:  I send the selection to the taskpane:
function ShowReport() {
var selCount = mapFrame.GetSelectedCount();
if(selCount != 0){
GetTaskFrame().GetTaskPane().location.href = homePage.replace("/MapGuide/MapViewerNet/","") + "?SESSION=" + mapFrame.GetSessionId() + "&LOCALE=" + locale + "&MAPNAME=" + mapFrame.GetMapName() + "&SELECTION=" + mapFrame.GetSelectionXML();
My homepage is actually a handler that interprets the selection - then fires the proper report:
Dim l_sSelect As String
Dim l_sMapName As String
Dim l_sSession As String
l_sMapName = Request("MAPNAME")
l_sSession = Request("SESSION")
l_sSelect = Request("SELECTION")
MapGuideApi.InitializeSockets()
'InitializeWebTier()
Dim l_oCred As New MgUserInformation(l_sSession)
'connect to the site and get a feature service and a resource service instances
Dim l_oSite As New MgSiteConnection()
l_oSite.Open(l_oCred)
Dim l_oFeatureSrvc As MgFeatureService = l_oSite.CreateService(MgServiceType.FeatureService)
Dim l_oResourceSrvc As MgResourceService = l_oSite.CreateService(MgServiceType.ResourceService)
'Create a temporary map runtime object, locate the layer
Dim l_oMap As New MgMap()
l_oMap.Open(l_oResourceSrvc, l_sMapName)
Dim l_oSel As MgSelection = New MgSelection(l_oMap, l_sSelect)
Dim l_cSelLayers As MgReadOnlyLayerCollection = l_oSel.GetLayers()
Now you can play with your selection.
Cheers,
Kori Maleski  BSc.
Senior Technical Consultant
Pacific Alliance Technologies
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
TEL 403.770.1917 FAX 877.691.9149 TOL 877.691.9171 www.pat.ca <http://www.pat.ca/>
From: Berdel, Brian [mailto:brian.berdel at mcmtrans.com]
Sent: Wed 26/04/2006 5:36 AM
Subject: RE: [mapguide-users] RE: PHP -> .NET Active Selection
I have not been able to get it to work with the DWF viewer either.  I
would appreciate some help here as well.
-----Original Message-----
Sent: Wednesday, April 26, 2006 5:54 AM
Subject: [mapguide-users] RE: PHP -> .NET Active Selection
Any progress to this one. I tried exactly what you specified in your
first
post using .NET. The problem is after the XML is passed to the other
page
and then when we try and do
MgMap map = new MgMap();
map.Open(resourceService, "wise");
MgSelection selection = new MgSelection(map);
if (selText != null && selText.Length > 0)
    selection.FromXml(selText); //It fails here
It now tells me "Attempted to read or write protected memory. This is
often
an indication that other memory is corrupt."
The selText is the XML that is submitted by
window.opener.mapFrame.GetSelectionXML() from some other page.
View this message in context:
http://www.nabble.com/RE%3A-PHP--%3E-.NET-Active-Selection-t1476910.html
#a4098462
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060426/17c80d95/attachment.bin
More information about the Mapguide_users mailing list
