Any work being done on fixing MS IE KB912945
Joel Carranza
jec at gatekeeper.com
Wed Apr 26 15:45:34 EDT 2006
Microsoft has deployed a "security" patch which forces you to "click to
activate" any ActiveX control before you can use it. It is exceptionally
annoying. Naturally, this affects the DWF Viewer. It also affects the
legend and property pane. If you havent already dealt with it, you can see
info about it here
http://www.microsoft.com/technet/security/advisory/912945.mspx. It is also
worth looking at http://support.microsoft.com/kb/912945
Has anyone looked at implementing the workaround? Can someone log this as an
artifact?
--Joel
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060426/c604b545/attachment.html
More information about the Mapguide_users
