[mapguide-users] Any work being done on fixing MS IE KB912945
Joel Carranza
jec at gatekeeper.com
Wed Apr 26 16:02:51 EDT 2006
Whoops.
Yeah, I looked for it and couldnt find it. Can you give me an Artifact ID?
Is there a release date for the next version of the DWF Viewer?
--Joel
_____
From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Sent: Wednesday, April 26, 2006 12:48 PM
Subject: RE: [mapguide-users] Any work being done on fixing MS IE KB912945
It's already been fixed in MapGuide. There was an artifact (you can search
for it :->).
The next release of DWF Viewer will also address this.
Walt
_____
Sent: Wednesday, April 26, 2006 3:46 PM
Subject: [mapguide-users] Any work being done on fixing MS IE KB912945
Microsoft has deployed a "security" patch which forces you to "click to
activate" any ActiveX control before you can use it. It is exceptionally
annoying. Naturally, this affects the DWF Viewer. It also affects the
legend and property pane. If you havent already dealt with it, you can see
info about it here
<http://www.microsoft.com/technet/security/advisory/912945.mspx>
http://www.microsoft.com/technet/security/advisory/912945.mspx. It is also
worth looking at <http://support.microsoft.com/kb/912945>
Has anyone looked at implementing the workaround? Can someone log this as an
artifact?
--Joel
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060426/c102c851/attachment.html
More information about the Mapguide_users
