[mapguide-users] RE: RE: Working with the current selection
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Apr 27 00:05:26 EDT 2006
Kalpesh,
As Andy mentioned, that's the expected contents for the selection XML.
The crash is the "interesting" part. Can you post a zip file containing
the actual XML string you were passing to MgSelection::FromXml and which
cuases the crash? We can then take a closer look at this.
Thanks,
Walt
-----Original Message-----
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, April 26, 2006 11:56 PM
Subject: RE: [mapguide-users] RE: RE: Working with the current selection
That XML sounds like it is OK. Those tags you are referring to is the
Base64 encoded feature ID values and you can only access them through
the
MapGuide API. It does sound like you are running into another problem,
however.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Wednesday, April 26, 2006 7:59 PM
Subject: [mapguide-users] RE: RE: Working with the current selection
I tried getting the selection from the client script by using
GetSelectionXML() and posting it to the .NET page. But when i refer to
this
xml by saying selection.fromXML(), it gives me a memory corrupt error.
The
XML looks like "<FeatureData......(a lot of tags in there having AQQQ,
BQQQ,
etc)"
Any alternative methods ?
View this message in context:
http://www.nabble.com/RE%3A-Working-with-the-current-selection-t1468388.
html
#a4113610
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
