Problems with $Currentselection
kalpesh kalpesh at pie-solution.com
Thu Apr 27 03:16:04 EDT 2006
Has anyone faced a problem with using $CurrentSelection in a DWF Viewer ?
I am having a Invoke URL script to which I am passing $Currentselection
which works fine if I have 'All Layers' kept as default under 'Use these
layers'.
If I select only a single layer which is selectable, the map throws a
Javascript error 'Object expected' in 'mainframe.templ'. This is on the
following line of code.
function OnSelectionChanged() {
//This line throws the error
var selLayers = GetSelectedLayers();
My understanding of this is,
The function GetSelectedLayers() is in dwfmappane.templ which is just not
referenced in this file. May this be a problem ?
View this message in context: http://www.nabble.com/Problems-with-%24Currentselection-t1516362.html#a4115792
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users mailing list
