[mapguide-users] Projections are shifting incorrectly....off by 10m
Andrew DeMerchant andrew.demerchant at gemtec.ca
Tue Aug 1 09:16:35 EDT 2006
Interestingly enough, it seems that all of my shp layers are fine. They
don't get shifted. I can bring them in using either system, and they
land right on top of each other. So the problem seems to be with DWF's
and Rasters...could it be those providers?
Andrew
Andrew DeMerchant wrote:
> Here's a screen capture of something. You're not seeing
> double....There are actually 2 dwf's here. One was brought into Studio
> using the default coord system (*XY-M*), and the other was brought
> into it using the actual coord system (CANST-NB-ATS) - which my Map is
> set to in Studio. All of the layers that I had brought in were
> originally brought in using the real system (CANST-NB-ATS). When it
> came to my rasters, I was noticing a shift that wasn't happening in my
> AutoCAD drawing. Yesterday, I finally traced it to this coord problem.
> I deleted my existing raster layers, and brought them in using the
> *XY-M* system....no shift. They lined up perfectly. After that, I
> added a new DWF layer. Same problem...It was shifted. Brought it in
> using *XY-M*, and the shift was gone. I've compared the output from
> MapGuide to my AutoCAD drawing, and the coords of the *XY-M* layers
> are correct. The shifted ones are incorrect.
> What I find curious about this, is the fact that either MapGuide or
> Studio is modifying the projection, even when the coord system of the
> layer matches the coord system of the map it's being used in. I would
> think that if the systems matched, it wouldn't try to transform
> anything...but it obviously is.
> Is this a bug in Studio, or a bug in MapGuide?  In anycase, it's
> making me question my other layers now....
> Andrew DeMerchant
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-4GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>For additional commands, e-mail: users-help at mapguide.osgeo.org
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
