[mapguide-users] Error with loading shp in MG studio
Tom Fukushima
tom.fukushima at autodesk.com
Fri Aug 4 10:57:31 EDT 2006
Hi Swati,
We noticed a problem with loading SHP files when the .dbf file has
multiple columns with the same name.
One way to check if this is the case is to try to import the .dbf into
Access. In MS Access: 1) create a new blank db, 2) File > Get External
Data > Import..., 3) select the dBase filter in the "Files of type" drop
down, then 4) select your .dbf file and press Import.
An error that states "The Microsoft Jet database engine could not find
the object 'xyz.dbf'. Make sure the object exists and that you spell
its name and the path name correctly" should come up.
Could you try the above and see if the same thing happens with your .dbf
files?
Thanks
Tom
-----Original Message-----
From: Swati Prabhu [mailto:swatip at bonair.stanford.edu]
Sent: Thursday, August 03, 2006 4:40 PM
Subject: [mapguide-users] Error with loading shp in MG studio
Thanks for the response. I did check it and no other application is
accessing the file. I have MG studio installed on the test server itself
and other than the Map server no other application is running. That
system
does have Autocad installed on it...
Content-Type: text/plain;
charset="us-ascii"
Date: Thu, 3 Aug 2006 15:23:30 -0700
The only case where I have seen that problem is when another application
has the shp files locked. Is it possible that this is the case?
Jason
Swati Prabhu,
Facilities Operations - Maps and Records
Stanford University
Phone: 650 723 0988 Fax: 650 723 7095
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
