[mapguide-users] MapGuide Open 1.0.1 and WMS problems
Andy Morsell amorsell at spatialgis.com
Mon Aug 7 18:11:29 EDT 2006
There is no entry for that WKT.  I am using the out-of-the-box
OgcWmsService.config.awd file with the exception of removing the errant
comment string.  I did try to add an entry last week per your
recommendations, but have reverted to the original file and have restarted
services, etc. Does that information get stored in another configuration
location that needs to be edited now?
Andy
-----Original Message-----
From: Thomas M. Tuerke [mailto:thomas.m.tuerke at autodesk.com]
Sent: Monday, August 07, 2006 2:56 PM
Subject: RE: [mapguide-users] MapGuide Open 1.0.1 and WMS problems
If that WKT is coming from SRS.WKT.map, try removing it from the map and
seeing what happens.
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Monday, August 07, 2006 2:52 PM
Hi Antonio,
I checked my file and see the same error (I'm kicking myself, I was looking
in this location just last week and didn't notice the error).  However,
after fixing it and then trying to generate the test WMS map from the
Sheboygan hydrography layer, I now get this error:
<ServiceExceptionReport version="1.1.1">  <ServiceException
code="InvalidCRS">
  The coordinate system is invalid. PROJCS["WGS 84",GEOGCS["WGS
84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]
],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251
994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]"
Could not parse the OGC WKT.<details>The coordinate system is invalid.
PROJCS["WGS 84",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
Exception occurred in method MgCoordinateSystem.MgCoordinateSystem at line
76 in file
c:\build_tux_area\mgdev_opensource\common\service\coordinatesystem\Coordinat
eSystem.cpp
</details>
 </ServiceException>
</ServiceExceptionReport>
Andy
From: Antonio de la Peña [mailto:antonio_dlp at dsgmexico.com.mx]
Sent: Monday, August 07, 2006 2:15 PM
Subject: Re: [mapguide-users] MapGuide Open 1.0.1 and WMS problems
Apparently the OgcWmsService.config.awd has a typo in the line 236 (or near
it) where it says:
  <!-- This example fixes a problem with EPSG:21781 not         -->
       finding the WKT for EPSG:21781 in the CS library.
As you can see there's an orphan commentary closing tag so I corrected it
like this:
       finding the WKT for EPSG:21781 in the CS library. -->
Then I restarted the server both MapGuide service and IIS and now the
"coordinate system conversion failed." error is gone.
I added the artifact MG348 addressing this issue.
View this message in context:
http://www.nabble.com/MapGuide-Open-1.0.1-and-WMS-problems-tf2025055.html#a5
696004
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
