WMS GetFeatureInfo Unsupported coordinate system code
Antonio de la Peña
antonio_dlp at dsgmexico.com.mx
Thu Aug 10 21:56:21 EDT 2006
I have managed to set up the WMS service correctly and I can see layer
images.
Now when I request information I keep getting this error:
The coordinate system conversion failed. Unsupported coordinate system code.
Exception occurred in method
MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 950 in file
c:\build_tux_area\mgdev_opensource\common\service\coordinatesystem\CoordinateSystem.cpp
The request string I'm sending is this:
http://201.139.35.10/mapguide/mapagent/mapagent.fcgi?REQUEST=GetFeatureInfo&SERVICE=WMS&VERSION=1.1.1&LAYERS=SCT/Layers/Carreteras&STYLES=&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:4326&BBOX=-104.706450805291,19.9223008154713,-102.902531372592,21.4064565528488&WIDTH=1117&HEIGHT=919&QUERY_LAYERS=SCT/Layers/Carreteras&X=509&Y=644
Previously I found an XML error in OgcWmsService.config.awd which I
referenced in artifact MG348 (more info in
http://www.nabble.com/MapGuide-Open-1.0.1-and-WMS-problems-t2025055.html#a5568417)
so I thought the same would applay here and I scanned 1.1.1.xml.awd and
found a probable error in line 62, a question mark that shouldn't be there
and I removed but it had no effect.
Has anyone made GetFeatureInfo work with the latest release? Have you had
this problem too? Thank you
View this message in context: http://www.nabble.com/WMS-GetFeatureInfo-Unsupported-coordinate-system-code-tf2088287.html#a5755742
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users
