[mapguide-users] AJAX in Mozilla-based broswers...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Aug 11 12:42:32 EDT 2006
I've tried a clean install of Mozilla Suite 1.7.12, 1.8b1, and Seamonkey
1.04....none ofd these work. In these browsers, there are no drop-down
menus at all. Firefox 1.5 works though, which is interesting, because
it's based on Mozilla 1.8....I wonder if I should file this as an artifact?
Andrew
Andrew DeMerchant wrote:
> Ah....so it does. The version of Firefox that I had tested it on was
> 3.0a, which didn't work. The Mozilla Suite and SeaMonkey don't work,
> but in those I have MultiZilla installed, with could maybe be blocking
> it (even though I've told it not to).....I'll try a clean mozilla
> suite install. Thanks
> Andrew
> James Card wrote:
>> On Fri, 11 Aug 2006 07:10:40 -0700, Andrew DeMerchant
>> <andrew.demerchant at gemtec.ca> wrote:
>>> Has anyone had success in getting the AJAX viewer to work properly in
>>> Mozilla-based browsers (like Firefox, SeaMonkey, Mozilla Suite, etc)? I
>>> can't seem to get drop-down menus working (like for zoom types) or
>>> right-click menus. I've tried turning off all security features in the
>>> browsers, but still nothing. Am I alone in this, or have others seen
>>> this too?
>> I regularly use Firefox to test our MapGuide projects, and have not
>> seen  the problems you describe. Your description is similar to the
>> problems  seen when trying to use the AJAX viewer in Opera; I'm
>> wondering whether  you have any Firefox extensions installed that
>> want to control right-click  handling.
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-4GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
