Dynamically Adding Layers to a Map with Selectable Features
Scott Reisdorf
reisdorf1 at llnl.gov
Fri Aug 18 12:18:26 EDT 2006
I am dynamically adding layers to my Map object, and would like the Map
to have the Features selected after the layer is loaded.
I have followed the DevGuide examples, and I get the new layers to
appear; however, the features on the layer are not selectable. Looking
into the base Map definition, I see that when a layer is added that can
be selected, additional XML nodes are added to the map as below, with
the 'Selectable == true'.
<MapLayer>
<Name>New Layer</Name>
<ResourceId>Library://.... </ResourceId>
*<Selectable>true</Selectable>*
<ShowInLegend>true</ShowInLegend>
<LegendLabel> </LegendLabel>
<ExpandInLegend>true</ExpandInLegend>
<Visible>true</Visible>
<Group></Group>
</MapLayer>
If I want my dynamic layers to be selectable, do I need to also update
the base Map Definition file too, or is there some other way via the API
that I can do this and have the new layer features be selectable.
Thanks,
-scott
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060818/a41204c0/attachment.html
More information about the Mapguide_users
