[mapguide-users] Tool tips and Labeling
Jason Birch
Jason.Birch at nanaimo.ca
Sat Aug 19 12:30:07 EDT 2006
There is no direct routing (or geocoding) capability in MapGuide. However you could implement this at the database level. Here's a link that might help:
http://chris.narx.net/2005/12/14/build-your-own-routing-solution/
I'm not sure if this will work with the OGR provider for PostGIS.
I guess you could set up a table that contains a cross product of all the nodes, along with the routes between them and the relative costs. This could get very, very large though.
Also, you'd have to build some logic to extract the portions of the lines between the start/destination points on the line and the nodes at the start/end of the shortest route.
You'd probably want to use a few different weighting mechanisms too: distance, speed, fewest left turns, etc.
This feature isn't of huge use to me, but I think it should be high on the wishlist.
Jason
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: Fri 2006-08-18 11:28 PM
Subject: Re: [mapguide-users] Tool tips and Labeling
Thanks a lot i've solved my problem
Now can any body help me how can i implement a routing algorithm on mapguide to find
the shortest path and as well as all posible path.
Is there any help or link available.
Thanks A Lot
Have A Nice Time
Have Fun
Be Jolly
Sukalyan Chakraborty
[Software Developer]
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060819/6c28df97/attachment.bin
More information about the Mapguide_users
