[mapguide-users] Mapguide installation question (win2000, Apache2, php5)
Jason Birch Jason.Birch at nanaimo.ca
Tue Aug 22 23:18:31 EDT 2006
Hmm.
Blank page isn't very much fun.
- change your php.ini file to display errors
- go through your php.ini file and make sure that its settings are compatible with the version that comes with MapGuide
- make sure you are running PHP 5.0.5; the MapGuide extension requires this
- speaking of which, did you install the MapGuide php extension?
Jason
Sent: Tue 2006-08-22 7:39 PM
Subject: [mapguide-users] Mapguide installation question (win2000, Apache2, php5)
Hi there,
I am trying to install mapguide with the following configuration.
Windows 2000 workstation
Apache 2 (a VC distribution version from Apache Lounge)
PHP5 (from php.net)
MapGuide
MapGuide Extension.
I can verify successfully that both Apache2 and Php5 are successfully installed and it works.
I followed the installation guide and I installed both the mapguide and its extension in my windows2000 box. When I call the mapguide related php (i.e.ajaxview.php), it return a blank page. I test it with my own php, it works. I wonder if I have to use the Apache2 and Php come with the extension?
Does anyone encounter this problem? Please help.
Thanks,
Elton
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060822/2f045d46/attachment.bin
More information about the Mapguide_users mailing list
