[mapguide-users] FDO provider for ODBC
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Aug 23 10:03:33 EDT 2006
I can definitely say that you're not alone with that performance issue.
I've found the ODBC FDO to be extremely slow as well. For my purposes, I
decided to just manually make my layer, and I'll just rebuild it
manually whenever I've got to add a new point. It was just too slow
using that provider.
Andrew
Bill MacDonald wrote:
> Hi,
> I am having issues displaying Point (x,y) data from a SQL Server table
> on a layer.
> I have tried the Autodesk FDO Provider for SQL Server but hadn't been
> able to get a geometry to appear when I created the layer.
> After that I had tried the OSGeo FDO provider for ODBC and connected
> to a SQL Server ODBC connection. This had given me the option to
> select my x & y values and the layer could successfully be created.
> The problem with this is that it is very slow (almost 1 min before the
> map will load now as opposed to the 10 seconds it used to take before
> the new layer was added).
> Does anyone know why the ODBC connection is so slow, or of how I could
> use the Autodesk FDO provider for SQL Server instead (I would assume
> that I should be using this provider instead of the ODBC anyways)?
> Thanks
> Billy MacDonald
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
