MapGuide Studio Preview Window
anakando
anakando at yahoo.com
Thu Aug 24 03:33:00 EDT 2006
Bill!!
i also have followed your suggestion..and running fine..thanks bill..we all
love you!
andrea tiveron - metodi srl wrote:
> Bill,
> I have followed your suggestion. uninstalled and installed.
> studio 2007 now works.
> thanks
> andrea
> _____
> From: Bill Dhimitri [mailto:bill.dhimitri at autodesk.com]
> Sent: Thursday, April 06, 2006 1:31 PM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] MapGuide Studio Preview Window
> Andrea,
> This error message can occur if you are using an older version
> (1.0.0.16407)
> of MapGuide Studio. That version of Studio does not work properly in
> locales where the decimal separator is a comma.
> To work around this problem, create a DWORD Value entry named Culture with
> a
> decimal value of 1033 in this registry folder:
> HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Autodesk MapGuide Studio\1.0.0.16407\
> Or you can uninstall Studio, delete the Studio folder, and then download
> and
> install the new Studio from www.autodesk.com/mapguidestudio.
> Bill
> _____
> From: andrea tiveron - metodi srl [mailto:andrea.tiveron at e-metodi.it]
> Sent: Thursday, April 06, 2006 2:54 AM
> Alain,
> thanks!
> the problem of aliases solved also my problem!
> now sheboygan sample map works, but not the layers
> I have the situation in the picture below.
> any idea?
> regards
> andrea
> _____
> From: Steven J Reed [mailto:sjreed at edcomputing.com]
> Sent: Thursday, April 06, 2006 12:27 AM
> Alain,
> That solved the problem! Both of my virtual folders were pointing to
> \mapviewerjava instead of \mapviewernet. Once I changed them it worked
> fine.
> Thanks!
> .Steve
> _____
> From: Alain Lebatard [mailto:alain.lebatard at autodesk.com]
> Sent: Wednesday, April 05, 2006 3:12 PM
> Steven,
> If the sample works ok for you, then the problem is most likely with the
> aliases 'mapviewerajax' and 'mapviewerdwf'
> In your IIS console:
> - Right click on 'mapguide' virtual folder and create a new
> virtual
> folder from the context menu. Name the virtual folder 'mapviewerajax' and
> set the physical path to <WebExtensionsDir>\mapviewernet. Give it the
> right
> to execute ASP scripts
> - Right click on the virtual folder 'mapviewerajax' and open the
> property dialog. In the 'Documents' tab, make sure that "Enable defaut
> document' is checked, remove any possible existing documents and add
> 'ajaxviewer.aspx' to the list
> virtual
> folder from the context menu. Name the virtual folder 'mapviewerdwf' and
> set
> the physical path to <WebExtensionsDir>\mapviewernet. Give it the right to
> execute ASP scripts
> - Right click on the virtual folder 'mapviewerdwf' and open the
> 'dwfviewer.aspx' to the list
> These virtual folders might already be defined on your machine but not
> correctly set up. If that's the case I'd suggest deleting them and
> recreating them with the steps above.
> Restart IIS. You should see the preview working in Studio.
> Alain
> _____
> Sent: Wednesday, April 05, 2006 1:56 PM
> Alain,
> I am using IIS on Windows XP Pro.
> Within Studio, I open any of the Samples/Sheboygan/Layouts, click Refresh
> in
> the Web Preview pane and all I see is text. (Not sure where I'm supposed
> to
> see 'Go').
> I can, however, view any and all of the samples via
> http://localhost/Mapguide/dotnetviewersample/dwfviewersample.aspx or
> http://localhost/Mapguide/phpviewersample/dwfviewersample.php.
> .Steve
> _____
> Sent: Wednesday, April 05, 2006 1:23 PM
> Steven,
> If you have an existing web layout in your repository, open it with
> Studio's
> web layout editor, and click 'Go' to preview the web layout within a web
> browser. If this is working then there is probably just a problem with the
> configuration of the aliases "mapviewerajax" and "mapviewerdwf" that
> Studio
> use for the preview window.
> However If you see the same problem in the web browser as in the preview
> window, then your web server is not properly configured to handle pages
> with
> a php extension (or jsp or aspx depending on what you are using), which
> causes these pages to be returned as text instead of being executed. Tell
> us
> also if you are using Apache or IIS, and if you are using PHP, JSP or
> ASP.NET.
> Alain
> _____
> Sent: Wednesday, April 05, 2006 12:47 PM
> Any suggestions as to why it doesn't????
> _____
> Sent: Wednesday, April 05, 2006 12:41 PM
> Yes. It should work.
> _____
> Sent: Monday, April 03, 2006 5:05 PM
> Subject: [mapguide-users] MapGuide Studio Preview Window
> Is this supposed to be working? Mine just shows html source, not any of
> the
> resources that are defined.
View this message in context: http://www.nabble.com/MapGuide-Studio-Preview-Window-tf1389497.html#a5959190
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users
