[mapguide-users] Tool tips and Labeling
Johann Muller johannfm at gmail.com
Fri Aug 25 01:45:11 EDT 2006
Is there any errors that occur when you run the command?
And what is the contents of *roads.sql *after you have run the command?
sukalyan chakraborty wrote:
> thanks a lot i've started my jouney on Shortest path calculation.. at
> the path of my journey
> i'm facing problem on *shp2pgsql D:\roads.shp roads > roads.sql *to
> convert the sql file into postgreSQL 8 format. it is not converting.
> Is there any help with anybody??
> On 8/19/06, *Jason Birch* <Jason.Birch at nanaimo.ca
> <mailto:Jason.Birch at nanaimo.ca>> wrote:
>     There is no direct routing (or geocoding) capability in
>     MapGuide.  However you could implement this at the database
>     level.  Here's a link that might help:
>     http://chris.narx.net/2005/12/14/build-your-own-routing-solution/
>     I'm not sure if this will work with the OGR provider for PostGIS.
>     I guess you could set up a table that contains a cross product of
>     all the nodes, along with the routes between them and the relative
>     costs.  This could get very, very large though.
>     Also, you'd have to build some logic to extract the portions of
>     the lines between the start/destination points on the line and the
>     nodes at the start/end of the shortest route.
>     You'd probably want to use a few different weighting mechanisms
>     too:  distance, speed, fewest left turns, etc.
>     This feature isn't of huge use to me, but I think it should be
>     high on the wishlist.
>     Jason
>     ________________________________
>     From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com
>     <mailto:chakraborty.sarkar at gmail.com>]
>     Sent: Fri 2006-08-18 11:28 PM
>     To: users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
>     Subject: Re: [mapguide-users] Tool tips and Labeling
>     Thanks a lot i've solved my problem
>     Now can any body help me how can i implement a routing algorithm
>     on  mapguide to find
>     the shortest path and as well as all posible path.
>     Is there any help or link available.
>     Thanks A Lot
>     Have A Nice Time
>     Have Fun
>     Be Jolly
>     Sukalyan Chakraborty
>     [Software Developer]
>     To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>     <mailto:users-unsubscribe at mapguide.osgeo.org>
>     For additional commands, e-mail: users-help at mapguide.osgeo.org
>     <mailto:users-help at mapguide.osgeo.org>
> Thanks A Lot
> Have A Nice Time
> Have Fun
> Be Jolly
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060825/37ac06fc/attachment.html
More information about the Mapguide_users mailing list
