[mapguide-users] Unable to open MapSelection
Farah farah at egovernments.org
Fri Aug 25 06:15:42 EDT 2006
Hi Bill..!!!
Thanks a lot! That solved my problem!!
Regards
Farah
  _____
From: Bill Dhimitri [mailto:bill.dhimitri at autodesk.com]
Sent: Friday, August 25, 2006 3:23 PM
Subject: RE: [mapguide-users] Unable to open MapSelection
Hi Farah,
Try using Open instead of open.
Bill
  _____
Sent: Friday, August 25, 2006 5:54 AM
Subject: [mapguide-users] Unable to open MapSelection
I need to iterate through the current map selection. However, the line
mapSelection.open()  gives the following error:
Does anyone know how to solve this problem?
Generated servlet error:
The method open(MgResourceService, String) is undefined for the type
MgSelection
My code:
MgResourceService resourceService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceServic
e);
MgMap map = new MgMap();
                        map.Open(resourceService, "Map");
                        MgSelection mapSelection = new MgSelection(map);
                        mapSelection.open(resourceService, "Map");
The definition for this method is:
virtual void
Open
<https://mapguide.osgeo.org/nonav/docs/webapi/d7/d8d/class_mg_selection_c068
d4f8815e003a4650cbea9c32bc00.html#c068d4f8815e003a4650cbea9c32bc00>
(MgResourceService
<https://mapguide.osgeo.org/nonav/docs/webapi/d8/de1/class_mg_resource_servi
ce.html>  *resourceService, CREFSTRING
<https://mapguide.osgeo.org/nonav/docs/webapi/da/d10/_common_defs_8h_2697935
ae7be4121104b37ff513b810b.html#2697935ae7be4121104b37ff513b810b>  mapName)
Regards
Farah
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060825/87d66bc9/attachment.html
More information about the Mapguide_users mailing list
