[mapguide-users] Capture click event on the map, using Mapguide Web API
Bill Dhimitri
bill.dhimitri at autodesk.com
Fri Aug 25 06:08:37 EDT 2006
In the MapGuide Studio Layer Editor, use the "URL activated for feature"
field to specify the URL. You can supply the URL as a simple string or
as an expression that incorporates one or more feature
attribute/property values.
In the MapGuide Studio WebLayout Editor, use the "Open Feature URL
hyperlinks in this target interface" drop down to control where to
display the results of the URL navigation: new window, task pane, or a
specific frame.
Bill
_____
Sent: Friday, August 25, 2006 1:44 AM
Subject: RE: [mapguide-users] Capture click event on the map, using
Mapguide Web API
Hi Sukalyan!
How do you do the URL activate for click event in Mapguide studio?
Thanks and Regards
Farah
_____
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: Friday, August 25, 2006 10:43 AM
Subject: Re: [mapguide-users] Capture click event on the map, using
Mapguide Web API
I have the same problem .. i want the help
You may handle the click event using URL activate for click event /
feature in Studio.
On 8/24/06, Farah <farah at egovernments.org> wrote:
Hi!
I am trying to develop a sample in which one of my requirements is to
click on a feature on the map and display some info, regarding that
feature, in the task pane. I am not able to capture the On-Click or
selection event of the map. Is there some way of doing this, using the
Web API?
Regards
Farah
Thanks A Lot
Have A Nice Time
Have Fun
Be Jolly
Sukalyan Chakraborty
[Software Developer]
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060825/ace732d0/attachment.html
More information about the Mapguide_users
