[mapguide-users] Tool tips and Labeling
Johann Muller johannfm at gmail.com
Fri Aug 25 08:22:22 EDT 2006
I dont know postgres/postgis well enough, but im guessing its using the
windows account that you have logged in with, in this case Administrator.
*psql **-U postgres -W **-d my_db -f country.sql
-U *spec*ifies user account
-W prompt for password
*Otherwise you  can use PgAdmin, open the database that you want yo use
and open the sql window, load the sql script file and run it.
sukalyan chakraborty wrote:
> *Yehhhh....   *
> thanks a lot... Johann
> I got the sql file with the write sql string.
> But now when i going to import the data into postgresql database
> using
> *psql -d my_db -f country.sql*
> it wants the password:
> i gave the password for the user postgres ;
> password is sukalyan.
> but it returns
> psql: FATAL: password authentication failed for user "Administrator"
> I've not yet any password for Administrator.
> is there any default password for Administrator??
> One more problem is i can not connect the server using pgadminIII
> On 8/25/06, *Johann Muller* <johannfm at gmail.com
> <mailto:johannfm at gmail.com>> wrote:
>     That is strange, here is one that i just tried. The " symbols are
>     just there because there is spaces in the filename.
>     /C:\street_data>shp2pgsql "Street 5m Buffer.shp " buffer > buffer.sql
>     Shapefile type: Polygon
>     Postgis type: MULTIPOLYGON[2]
>     Then the beginning of my buffer.sql:
>     BEGIN;
>     CREATE TABLE "buffer" (gid serial PRIMARY KEY,
>     "prefix" varchar(2),
>     "name" varchar(50),
>     "type" varchar(15),
>     "suffix" varchar(2),
>     "full_name" varchar(50),
>     "alt_name" varchar(50),
>     "label" varchar(50),
>     "route" varchar(30),
>     "roadclass" varchar(10),
>     "category" varchar(20),
>     "province" varchar(30),
>     "municipal" varchar(50),
>     "cityname" varchar(30),
>     "oldcity" varchar(35),
>     "sub_left" varchar(35),
>     "sub_right" varchar(35),
>     "f_zlev" int2,
>     "t_zlev" int2,
>     "oneway" varchar(2),
>     "ramp_flag" varchar(1),
>     "br_flag" varchar(1),
>     "tn_flag" varchar(1),
>     "meters" numeric,
>     "speed_lim" int2);
>     SELECT
>     AddGeometryColumn('','buffer','the_geom','-1','MULTIPOLYGON',2);/
>     Once you have the buffer.sql you need to run this script on your
>     database to import the data.
>     The usage of the sh2sqlpgsql is as follows
>     shp2pgsql shape_file table_name > output_sql_file
>     Maybe try the following:
>     *shp2pgsql D:\roads.shp roads > d:\roads.sql
>     ***Then go to the D: drive and the contents of the file roads.sql
>     Hope this helps.
>>     roads.sql is blank after running this .
>>     and it is running if i provide the commnd
>>     *shp2pgsql D:\roads.shp roads.sql *
>>     then postgre running the command and showing the extraction data
>>     from shp file but
>>     i'm sorry to say u that after that also the roads.sql file is blank.
>>     i'm also unable to see the database from postgre database window.
>>     <mailto:johannfm at gmail.com> > wrote:
>>         Is there any errors that occur when you run the command?
>>         And what is the contents of *roads.sql *after you have run
>>         the command?
>>>         thanks a lot i've started my jouney on Shortest path
>>>         calculation.. at the path of my journey
>>>         i'm facing problem on *shp2pgsql D:\roads.shp roads >
>>>         roads.sql *to convert the sql file into postgreSQL 8 format.
>>>         it is not converting. Is there any help with anybody??
>>>         On 8/19/06, *Jason Birch* <Jason.Birch at nanaimo.ca
>>>         <mailto:Jason.Birch at nanaimo.ca>> wrote:
>>>             There is no direct routing (or geocoding) capability in
>>>             MapGuide.  However you could implement this at the
>>>             database level.  Here's a link that might help:
>>>             http://chris.narx.net/2005/12/14/build-your-own-routing-solution/
>>>             I'm not sure if this will work with the OGR provider for
>>>             PostGIS.
>>>             I guess you could set up a table that contains a cross
>>>             product of all the nodes, along with the routes between
>>>             them and the relative costs.  This could get very, very
>>>             large though.
>>>             Also, you'd have to build some logic to extract the
>>>             portions of the lines between the start/destination
>>>             points on the line and the nodes at the start/end of the
>>>             shortest route.
>>>             You'd probably want to use a few different weighting
>>>             mechanisms too:  distance, speed, fewest left turns, etc.
>>>             This feature isn't of huge use to me, but I think it
>>>             should be high on the wishlist.
>>>             Jason
>>>             ________________________________
>>>             From: sukalyan chakraborty [mailto:
>>>             chakraborty.sarkar at gmail.com
>>>             <mailto:chakraborty.sarkar at gmail.com>]
>>>             Sent: Fri 2006-08-18 11:28 PM
>>>             To: users at mapguide.osgeo.org
>>>             <mailto:users at mapguide.osgeo.org>
>>>             Subject: Re: [mapguide-users] Tool tips and Labeling
>>>             Thanks a lot i've solved my problem
>>>             Now can any body help me how can i implement a routing
>>>             algorithm on  mapguide to find
>>>             the shortest path and as well as all posible path.
>>>             Is there any help or link available.
>>>             Thanks A Lot
>>>             Have A Nice Time
>>>             Have Fun
>>>             Be Jolly
>>>             Sukalyan Chakraborty
>>>             [Software Developer]
>>>             To unsubscribe, e-mail:
>>>             users-unsubscribe at mapguide.osgeo.org
>>>             <mailto:users-unsubscribe at mapguide.osgeo.org>
>>>             For additional commands, e-mail:
>>>             users-help at mapguide.osgeo.org
>>>             <mailto:users-help at mapguide.osgeo.org>
>>>         Thanks A Lot
>>>         Have A Nice Time
>>>         Have Fun
>>>         Be Jolly
>>     Thanks A Lot
>>     Have A Nice Time
>>     Have Fun
>>     Be Jolly
> Thanks A Lot
> Have A Nice Time
> Have Fun
> Be Jolly
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060825/94ed7ece/attachment.html
More information about the Mapguide_users mailing list
