[mapguide-users] Handle Click Event On Map
Maciej Skorczewski
maciej.skorczewski at procad.pl
Tue Aug 29 05:16:28 EDT 2006
hi
just use javascript handle
ex:
function watchInitialized ()
try {
if(ViewerFrame.mapFrame.mapInit)
clearInterval(initTimer);
originalOnSelectionChanged = ViewerFrame.OnSelectionChanged;
ViewerFrame.OnSelectionChanged = show_file;
catch(Exception) {}
show_file is a js function ,you can write what script should do.
maciek.
sukalyan chakraborty napisał(a):
> i want to use my own code on map frame click event means when user click
> on map.
> Now in the map pane or in the main.tmpl or map.tmpl where i will write
> can you specify the position.
> i've already writen the code in onmapclick event in map.tmpl but it is
> not working.
More information about the Mapguide_users
