[mapguide-users] Insertation (reference) point of symbols
Willem Schwarte willem at giskit.nl
Tue Aug 29 12:06:27 EDT 2006
No, I have uses both . and , for decimals...
From: Ing. Cristian Galdini [mailto:galdini at dek.it]
Sent: Tue 8/29/2006 5:39 PM
Subject: Re: [mapguide-users] Insertation (reference) point of symbols
Tanks,
but my experience is that
different setting of decimal point  ( , or . )
has not resolved the problem
cristian
Tom Fukushima wrote:
	I've traced this problem down to systems where a "," is used as the decimal point. We should have fixes submitted for this shortly.
	In the meantime the techniques used in this thread http://www.nabble.com/ODBC---Successful-connection---FINALLY%21%21%21%
	21%21%21-tf2026417.html <http://www.nabble.com/ODBC---Successful-connection---FINALLY%21%21%21%21%21%21-tf2026417.html>  might also solve this problem.
	Regards
	Tom
	-----Original Message-----
	Sent: Tuesday, August 29, 2006 8:04 AM
	Subject: RE: [mapguide-users] Insertation (reference) point of symbols
	I've had this problem too on Windows. On Linux everything is perfect aligned!
	-----Oorspronkelijk bericht-----
	Van: Ing. Cristian Galdini [mailto:galdini at dek.it]
	Verzonden: dinsdag 29 augustus 2006 9:45
	Aan: users at mapguide.osgeo.org
	Onderwerp: Re: [mapguide-users] Insertation (reference) point of symbols
	Hi, i have the same problem,
	In my case, the server works fine as an application instead as a service (!)
	from prompt "mgserver /interactive"
	IBB Ingenieurbüro Battefeld wrote:
		all symbols has offset. It means, in the original drawing (dwg) the
		base point of each block (a simple circle) is the center point. But in
		the viewer each symbol seems to has an offset. The change of the
		reference point in MapGuide Studio is without effect. It's the same if
		I use dwg- or shp-format.
		What could be wrong?
		Thanks in advance - Peter
		P.s.: I'm using MapGuide Server 1.0.1.17812 and MapGuide Studio
		1.0.0.17804
		To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
		For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060829/5a59a51f/attachment.bin
More information about the Mapguide_users mailing list
