Problem with mapguide-1.0.0 installation
kleymuk at sibmail.com kleymuk at sibmail.com
Wed Aug 30 03:56:56 EDT 2006
I just have this error after 'make check' command:
Running the server unit tests.
(3382|3033085616) MgServer::MgServer()
(3382|3033085616) MgServer::init()
(3382|3033085616) MgServer::ParseArgs()
(3382|3033085616) MgServer::init() - Loading configuration.
(3382|3033085616) MgServer::init() - Initializing Log Manager.
(3382|3033085616) MgServer::init() - Loading resources.
(3382|3033085616) MgServer::init() - Initializing License Manager.
(3382|3033085616) MgServer::init() - Initializing Server Manager.
(3382|3033085616) MgServer::init() - Initializing Load Balance Manager.
(3382|3033085616) MgLoadBalanceManager::Initialize()
(3382|3033085616) MgServer::init() - Initializing Service Manager.
(3382|3033085616) MgServiceManager::Initialize() - Creating services.
(3382|3033085616) MgServiceManager::Initialize() - Creating Server Admin
Service.
(3382|3033085616) The specified service is not supported.
Exception occurred in method CreateService at line 211 in file
Services/SiteConnection.cpp
(3382|3033085616) MgServer::~MgServer()
(3382|3033085616) MgSessionCache::~MgSessionCache()
(3382|3033085616) MgServiceManager::~MgServiceManager()
(3382|3033085616) MgServerManager::~MgServerManager()
(3382|3033085616) MgLogManager::~MgLogManager()
Cannot load server factory DLL : libMgServerFactory.so: cannot open shared
object file: No such file or directoryFAIL: unittest.sh
1 of 1 tests failed
make[4]: *** [check-TESTS] Error 1
make[4]: Leaving directory `/home/serg/mapguide-1.0.0/Server/src/Core'
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/home/serg/mapguide-1.0.0/Server/src/Core'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/home/serg/mapguide-1.0.0/Server/src'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/home/serg/mapguide-1.0.0/Server'
make: *** [check-recursive] Error 1
More information about the Mapguide_users mailing list
