[mapguide-users] Access DB and coord systems
Traian Stanev
traian.stanev at autodesk.com
Wed Aug 30 15:40:28 EDT 2006
One thing I can think of would be if your ODBC connection lists more
than one coordinate system when queried by the server and the server
then could end up using the wrong one for repro, which would result in
the behavior you describe. Another possibility is that it didn't parse
the WKT string correctly for the ODBC connection, although that's
unlikely, given that LL83 is a popular one.
Traian
_____
From: Gord McKenzie [mailto:gord.mckenzie at canam.com]
Sent: Wednesday, August 30, 2006 3:34 PM
Subject: [mapguide-users] Access DB and coord systems
I have a table in access with lat and long. I can create and
successfully Test Connection to the ODBC database which is identified as
LL83. I can create a layer, a map and a web layout that will show this
data. If I set my map coord system to UTM zone, the data is not
transformed. I can add shape and sdf layers that are LL83 source and
reproject just fine. Only DB data sources don't seem to want to
reproject.
Can anyone offer any reason or advice?
Thanks
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060830/92b34081/attachment.html
More information about the Mapguide_users
