[mapguide-users] Oracle Spatial v/s Oracle Locator with MapGuide FDO
Simon Greener
sgreener at netspace.net.au
Thu Aug 31 15:52:26 EDT 2006
Rob,
> The Oracle provider doesn't require the F_* tables to work with
> MapGuide. It has some restriction if they are not present but the data
> should be readable in MapGuide through the provider. The F_* are used
> to store the FDO metadata. If these tables are not present, the FDO
> schema will be generated by reverse engineering the Oracle table
> definitions.
> If you have some use case that doesn't work, we certainly would like to
> know about it.
Always happy to admit when I am wrong.... We could not connect properly
without the
tables using some straight C++. I can't remember the return code from the
FDO interface
but when we created the tables the connection succeeded. Then we could not
read any data
so we tried to create the "layer" definitions... we gave up. So, if there
is a property
of the connection class we need to set to make it work with native OS
table/columns as
recorded in *_SDO_GEOM_METADATA we are all ears! ;-) Some example C++ code
might help!
regards
S
SpatialDB Advice, Solutions Architect, Manifold Enthusiast, Oracle Spatial
Specialist.
Allens Rivulet, Tasmania, Australia.
Voice: +61 3 62396397
Longitude: 147.2048
Latitude: -43.0141
More information about the Mapguide_users
