[mapguide-users] GetSelectionXML() how to read <Class id='Default:xxx'>
in PHP.
Maciej Skorczewski
maciej.skorczewski at procad.pl
Fri Dec 1 09:44:34 EST 2006
hi Alain !
i have one guestion - when i create new layer on my map (ParcelMarker).
ex. add a marker of BUS. and i click on it(market is selectable) i get
this message.
Fatal error: Uncaught exception 'mginvalidpropertytypeexception' in
Unknown on line 0
this is strange, on static layer i have no problem whit this.
what is wrong?
Maciej Skorczewski
PROCAD SA - Autodesk Systems Center
www.procad.pl
> Hi Maciej,
> Have you looked at the MgSelection class? It can parse the XML text
> representing the selection and give you the list of layers that are part
> of this selection.
> The following code output the name of the selected layers
> $sel = new MgSelection($map, $xmlSelText);
> $layers = $sel->GetLayers();
> for($i = 0; $i < $layers->GetCount(); $i++)
> $layer = $layers->GetItem($i);
> echo $layer->GetName() . "\n";
More information about the Mapguide_users
