[mapguide-users] Select Distinct QueryOption or Filter?
Traian Stanev
traian.stanev at autodesk.com
Tue Dec 5 22:04:42 EST 2006
You should use MgFeatureService::SelectAggregates() to do a distinct select.
In the FeatureAggregateOptions object that is passed as argument to that call, make sure you set the distinct flag by calling MgFeatureAggregateOptions::SelectDistinct(true).
Traian
-----Original Message-----
From: Scott Reisdorf [mailto:reisdorf1 at llnl.gov]
Sent: Tue 12/5/2006 7:28 PM
Cc:
Subject: Re: [mapguide-users] Select Distinct QueryOption or Filter?
Thanks Dave.
I am using SDF3, and from the provider it says it supports
SelectDistinct (<SupportsSelectDistinct>true</SupportsSelectDistinct> )
I now dont know how to set the Flag in the QueryOptions to be Distinct.
Looking at the API and the code, it does not appear that the Distinct
option is available on the QueryOptions. Does anyone know how to select
Distinct Features using the FeatureService?
Thanks,
-scott
Dave Wilson wrote:
> Not all providers support distinct.
> You need to check the GetCapabilities for each provider via
> http://localhost/mapguide/mapagent/index.html under FeatureServices -
> GetProviders will list your providers. Then using GetCapabilities it
> will indicate if it supports Distinct. Distinct is a flag in the
> QueryOptions that can be set if I recall correctly.
> Dave
> Sent: Tuesday, December 05, 2006 2:50 PM
> Subject: [mapguide-users] Select Distinct QueryOption or Filter?
> All,
> Is there a way to query DISTINCT Features when using the
> FeatureService.SelectFeatures() or SelectAggregrate() with the
> QueryOptions, or possibly is there a "Distinct" filter option available.
> Any help or code/source documenting this would be helpful.
> Thanks,
> -scott
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061205/8075c18b/attachment.html
More information about the Mapguide_users
