[mapguide-users] Map guide stress testing
Traian Stanev
traian.stanev at autodesk.com
Mon Dec 11 22:33:48 EST 2006
Sure you can use any tool you wish. I know we (but not me personally) have used JMeter for similar stress testing and it has worked fine. It looks like the tool you link to does a similar job. What exactly are you trying to measure, and is there an actual performance problem you are seeing?
Traian
-----Original Message-----
From: kencana kesuma [mailto:bluesky_dyx at hotmail.com]
Sent: Mon 12/11/2006 8:31 PM
Cc:
Subject: RE: [mapguide-users] Map guide stress testing
Hi Traian,
Thanks for your reply.Anyway, can i use web application load and stress
testing tools,
instead of running the code you have given to me? I found a lot of this kind
of tools from
the internet. the following is one of them.
I was wondering, can i use this tools for the stress testing?
http://www.neotys.com/?gclid=CIuc5paZiokCFRJLTAodEB6MkQ
Maybe you can give me some guidelines about this testing phase.
Thank you
Regards,
Kencana
>From: "Traian Stanev" <traian.stanev at autodesk.com>
>Reply-To: users at mapguide.osgeo.org
>To: <users at mapguide.osgeo.org>
>Date: Mon, 11 Dec 2006 11:56:05 -0500
>For a fun way to do it... I have used the attached (rather sadistic)
>script in the past. It does many many GetMapImage requests.
>You will need to customize it with the bounds/center/scale of a map
>definition of your choice. Then open it in Firefox and watch it churn.
>For maximum pain you can go to "about:config" in Firefox and boost the
>number of simultaneous http connections allowed. Then it should be
>requesting multiple GetMapImages in parallel. The cool part is that the
>returned images will get displayed and tiled correctly in the browser.
>Traian
>From: Kencana [mailto:bluesky_dyx at hotmail.com]
>Sent: Monday, December 11, 2006 5:04 AM
>Subject: [mapguide-users] Map guide stress testing
>Hi all,
>I was wondering, is there a way to perform a stress test to mapguide
>access?
>as I need to know whether mapguide is capable to handle hundreds or
>maybe thousands user access or not.
>the main thing is i need to know the maximum access capacity that can be
>handle by mapguide.
>Any idea of this issue?
>Thank you
>Regards,
>Kencana
>View this message in context:
>http://www.nabble.com/Map-guide-stress-testing-tf2792981.html#a7792120
>Sent from the MapGuide Users mailing list archive at Nabble.com.
>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>For additional commands, e-mail: users-help at mapguide.osgeo.org
><< getmaptest2.html >>
_________________________________________________________________
FREE pop-up blocking with the new MSN Toolbar - get it now!
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061211/2f376682/attachment.html
More information about the Mapguide_users
