[mapguide-users] RE: Map guide stress testing
Traian Stanev
traian.stanev at autodesk.com
Tue Dec 12 09:19:53 EST 2006
I think JMeter works against any HTTP server, so it should work against
IIS.
Traian
-----Original Message-----
Sent: Monday, December 11, 2006 10:48 PM
Subject: [mapguide-users] RE: Map guide stress testing
Hi Traian,
Thanks for your reply.I am trying to measure, what is the maximum load
that can be handle by the mapguide server.
as there might be more than 10000 ++ user might access to the map daily.
So I need to know whether the server can handle it or not.
by the way "JMeter" is for apache server is it?
as i am using IIS, can I use this tool?
Thank you
Regards,
Kencana
Traian Stanev wrote:
> Sure you can use any tool you wish. I know we (but not me personally)
> have used JMeter for similar stress testing and it has worked fine. It
> looks like the tool you link to does a similar job. What exactly are
> you trying to measure, and is there an actual performance problem you
are seeing?
> Traian
> From: kencana kesuma [mailto:bluesky_dyx at hotmail.com]
> Sent: Mon 12/11/2006 8:31 PM
> Cc:
> Subject: RE: [mapguide-users] Map guide stress testing
> Hi Traian,
> Thanks for your reply.Anyway, can i use web application load and
stress
> testing tools,
> instead of running the code you have given to me? I found a lot
of
> this kind
> of tools from
> the internet. the following is one of them.
> I was wondering, can i use this tools for the stress testing?
> http://www.neotys.com/?gclid=CIuc5paZiokCFRJLTAodEB6MkQ
> Maybe you can give me some guidelines about this testing phase.
> Thank you
> Regards,
> Kencana
> >From: "Traian Stanev" <traian.stanev at autodesk.com>
> >Reply-To: users at mapguide.osgeo.org
> >To: <users at mapguide.osgeo.org>
> >Date: Mon, 11 Dec 2006 11:56:05 -0500
> >For a fun way to do it... I have used the attached (rather
sadistic)
> >script in the past. It does many many GetMapImage requests.
> >You will need to customize it with the bounds/center/scale of a
map
> >definition of your choice. Then open it in Firefox and watch it
churn.
> >For maximum pain you can go to "about:config" in Firefox and
boost the
> >number of simultaneous http connections allowed. Then it should
be
> >requesting multiple GetMapImages in parallel. The cool part is
that the
> >returned images will get displayed and tiled correctly in the
browser.
> >Traian
> >From: Kencana [mailto:bluesky_dyx at hotmail.com]
> >Sent: Monday, December 11, 2006 5:04 AM
> >Subject: [mapguide-users] Map guide stress testing
> >Hi all,
> >I was wondering, is there a way to perform a stress test to
mapguide
> >access?
> >as I need to know whether mapguide is capable to handle
hundreds or
> >maybe thousands user access or not.
> >the main thing is i need to know the maximum access capacity
that can be
> >handle by mapguide.
> >Any idea of this issue?
> >Thank you
> >Regards,
> >Kencana
> >View this message in context:
>http://www.nabble.com/Map-guide-stress-testing-tf2792981.html#a7792120
> >Sent from the MapGuide Users mailing list archive at
Nabble.com.
> >To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> >For additional commands, e-mail: users-help at mapguide.osgeo.org
> ><< getmaptest2.html >>
_________________________________________________________________
> FREE pop-up blocking with the new MSN Toolbar - get it now!
> http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
http://www.nabble.com/Map-guide-stress-testing-tf2792981.html#a7826915
More information about the Mapguide_users
