[mapguide-users] Finding list of Mapdefinitions
Dave Wilson
dave.wilson at autodesk.com
Tue Dec 12 18:21:16 EST 2006
Thanks Scott. Beat me to it.
With the DOM parser you can search on the <ResourceId> tag and parse the
name of the map, here's an example value:
<ResourceId>Library://QE_Data/Maps/SDF2.0_Dublin_CA83IIIF.MapDefinition<
/ResourceId>
By the way it's Library://
// and not \\ just in case you missed that too.
Dave
_____
From: Scott Reisdorf [mailto:reisdorf1 at llnl.gov]
Sent: Tuesday, December 12, 2006 4:18 PM
Subject: Re: [mapguide-users] Finding list of Mapdefinitions
In Java you can do something like this, creating a ByteArrayOutputStream
and then displaying that stream back as a String.
ByteArrayOutputStream bos = new ByteArrayOutputStream();
byte[] byteBuffer = new byte[1024];
int numBytes = byteReader.Read(byteBuffer, 1024);
while(numBytes > 0)
bos.write(byteBuffer, 0, numBytes);
System.out.println(bos.toByteArray());
or you can get straight XML back from the MgByteReader, and then parse
that:
MgByteReader byteReader =
resourceService.EnumerateResources(resId,-1,MgResourceType.MapDefinition
String xml = byteReader.ToString();
// ...parse the xml via the DOM
hope this helps
-scott
Scott Hameister wrote:
Did that, but I get an MgByteReader object with no clue how to
iterate...isn't there a count/getitem method I could use or do I have to
convert to a string and Parse or something?
_____
From: Dave Wilson [mailto:dave.wilson at autodesk.com]
Sent: Tuesday, December 12, 2006 4:54 PM
Subject: RE: [mapguide-users] Finding list of Mapdefinitions
Try MapDefinition
Case sensitive.
_____
From: Scott Hameister [mailto:ScottH at mPower-tech.com]
Sent: Tuesday, December 12, 2006 3:53 PM
Subject: [mapguide-users] Finding list of Mapdefinitions
Pulling my Hair out I'm just trying to get a list of
Mapdefinitions in the Library:\\
I tried doing EnumerateResources on Library\\: with -1 and
Mapdefinition, but can't find an API way to get the names....Am I way
off target here?
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061212/0110b1eb/attachment.html
More information about the Mapguide_users
