[mapguide-users] Saving map to session doesn't persist?
Jason Birch
Jason.Birch at nanaimo.ca
Tue Dec 12 18:32:34 EST 2006
Replying to myself, one of the developer samples shows how to use the
RenderingService.
http://data.mapguide.com/mapguide/devguide/viewsource.php?FILENAME=D%3A%
5CMapGuideOpenSourceWeb%5Cwww%5Cdevguide%5Ccustom_output%2Fcreatemapimag
e.php
I wonder why I didn't see this before...
Jason
-----Original Message-----
Sent: Friday, November 17, 2006 13:42
Subject: RE: [mapguide-users] Saving map to session doesn't persist?
As an aside, I could REALLY use an example of how to use the
RenderingService in PHP instead of having to waste cycles passing the
map through the repository. The php viewer sample utilityfunctions.php
has a function called OutputReaderContent which should help, but I have
a few questions about how to do DPI / width calculations (are the width
and height in RenderMap in map units?) and a couple other things.
More information about the Mapguide_users
