[mapguide-users] Problems with Mapguide Open Source Web Studio Hekp Guide
Zak James zak4ms at gmail.com
Thu Dec 14 21:29:36 EST 2006
Chris:
You shouldn't need any special configuration to make use of webstudio:
with a default install it should work as is.
One issue you may be experiencing is a change in how user roles are
handled in version Mapguide 1.1rc1. The Administrator user doesn't
have the Author role and can't complete some of the steps necessary to
build a map (I think this is the case, but I'm not sure). You could
try accessing the Mapguide Site Admin application via Web Studio's
Tools->Site Administrator menu item and creating a user with the
Author role.
Hope this helps.
zak
On 12/14/06, Chris Gountanis <cgountanis at mpower-tech.com> wrote:
> On the same topic has anyone been able to use web studio to add shape files
> and create a map even? Not sure what I am doing wrong out of the box. Does
> it need special INI or FDO setup prior to using. The help files are missing
> as well.
> Chris
>  ________________________________
>  From: Aliadne Goes [mailto:aliadne.goes at gmail.com]
> Sent: Thursday, December 14, 2006 12:42 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] Problems with Mapguide Open Source Web Studio Hekp
> Guide
> Hello
> I am trying to execute the Mapguide Open Source Web Studio with MapGuide
> Open Source 1.1.0 Release Candidate 1, but I can't see the Web Studio Help
> Guide, therefore when I open the page appear the folow messenger:
> Not Found
> The requested URL /mapguide/webstudio/help/concept_map.html
> was not found on this server.
> The requested URL
> /mapguide/webstudio/help/concept_layer.html was not found
> on this server.
> The requested URL
> /mapguide/webstudio/help/concept_featuresource.html was not
> Apache/2.0.55 (Win32) mod_fastcgi/2.4.2 mod_jk/1.2.15 Server at cpqd050203
> Port 8008
> Where can I found the complete help guide? I need to create a new map, but I
> don't have anything guide.
> Regards,
> Aliadne
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
More information about the Mapguide_users mailing list
