[mapguide-users] Map 3D 2007 Publish to Map
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Fri Dec 15 13:55:53 EST 2006
It may not happen every time in the future, but it's happened most of
the time (if not all) so far...I realize that this is a very new
project, and it's growing and changing fast, so maybe this is
unavoidable for now....if it's application-level checks that are causing
most of the problems, then I agree, those shouldn't be in there.
Andrew
Jason Birch wrote:
> It's a different error this time though :)
> I'm not sure that it's "safe" to assume that Studio will work with a
> newer Open Source release, especially a full point-release rather than
> a fix release. Like any good project, we'll be trying to maintain
> backwards compatibility, but from time to time there will likely be
> changes that require an API change.
> However, I don't think that there should be application-level checks
> on the version. If users want to risk running an older version of
> Studio than MG, that should be up to them.
> Jason
> *From:* Andrew DeMerchant
> *Sent:* Friday, December 15, 2006 10:15
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Map 3D 2007 Publish to Map
> Maybe this problem should be thought about a bit. This happens every
> single time there's an update for MapGuide Server....Studio breaks
> (and now maybe Map 3D, who knows what else). Seems to me that, this
> being an open source product that will be releasing updates quite
> regularly, someone needs to come up with a solution to this. Surely
> there's a way to make it so that these programs don't break with every
> little release. Just a thought.....problems like this can be pretty
> irritating, and for users that don't have the patience / knowledge to
> fix it, it may push them away.
> Andrew
> Bill Dhimitri wrote:
>> Nothing official yet. It might be as simple as taking the same DLL
>> that Tom posted and overwriting the one in the Map directory. But I
>> don't think anyone has confirmed that this will work.
>> Bill
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
