[mapguide-users] MgException - MgOutofMememory - Out of memory.
Kori Maleski kmale at telus.net
Sat Dec 16 02:20:01 EST 2006
I watched it for over 3 hours and observed the point of the error.
Most exciting Friday night ever.
I don't think it is a memory error - the memory usage stayed relatively
flat.  The increase over time ended up being minimal.
I think there is a loss of connectivity just prior that results in the error
being thrown.  Perhaps the site connection expires - and the way the
function is written it does the next GetTile but not without rights.
Hard to tell which is cause and which is effect.
I just checked the Access log and that confirms it.
Before error:
<2006-12-15T22:21:39> 			Administrator
GetTile.1:4(MgMap,Map,tileCol,tileRow) Success
<2006-12-15T22:21:41> 			Administrator
<2006-12-15T22:21:42> 			Administrator
Error thrown:
<2006-12-15T22:21:43> 			Administrator
GetTile.1:4(MgMap,Map,tileCol,tileRow) Failure
If I try to continue past the error by restarting my application but not
restarting the MapGuide Server service (notice the Admin account is not
present and there is no CreateSession etc):
<2006-12-15T22:23:45>
If I restart the MapGuide Service:
<2006-12-15T22:49:24> 			Administrator	CreateSession.1:0()
Success
GetResourceContent.1:2(MgResourceIdentifier,) Success
<2006-12-15T22:49:29> 			Administrator
It does the initial config correctly.
In my ServerConfig.ini I have the following settings:
SessionTimerInterval = 400
SessionTimeout = 86400
I do an HTTP call within the 400 second interval to keep the session fresh.
I will continue to review my code to see if I am missing something.
Is the session expiring or failing in some manner possibly?
Cheers and thanks,
Kori
-----Original Message-----
Sent: December 15, 2006 7:32 PM
Subject: RE: [mapguide-users] MgException - MgOutofMememory - Out of memory.
I am using MapGuide Enterprise Service Pack 1 for this test.  The more
recent Open build may fare better.  I am still in the process of getting a
machine up.
Increasing the paging file didn't work.  It still threw the Out of memory
error.  I missed the actual occurrence of the error - so I am not sure if
the memory usage peaked unusually high - I don't think it did.
It only got to 336000 k.
If I tried to re-run my process I got the same error.
If I restarted MapGuide Service, it ran fine.
So I am not sure if it is truly a memory error or a loss of connectivity
before.
I will keep running and documenting over the weekend.
Cheers,
The sequence of errors according to the log file:
<2006-12-15T19:09:31> 			Administrator
 Error: Failed to stylize layer: 100K_Urban_California
        An unclassified exception occurred.
 StackTrace:
  - MgStylizationUtil.StylizeLayers line 993 file
c:\build_tux_area\mgdev\server\src\services\mapping\StylizationUtil.cpp
 Error: Failed to stylize layer: 2M_ocean_mask_California
        Out of memory.
        bad allocation
 StackTrace:
Out of memory.
bad allocation
<2006-12-15T19:09:32> 			Administrator
 Error: Out of memory.
        bad allocation
 StackTrace:
  - MgTileServiceHandler.ProcessOperation line 83 file
c:\build_tux_area\mgdev\server\src\services\tile\TileServiceHandler.cpp
  - MgOpGetTile.Execute line 97 file
c:\build_tux_area\mgdev\server\src\services\tile\OpGetTile.cpp
  - MgServerTileService.GetTile line 85 file
c:\build_tux_area\mgdev\server\src\services\tile\ServerTileService.cpp
  - MgServerTileService.SetTile line 119 file
  - MgByteSink::ToFile line 245 file
c:\build_tux_area\mgdev\common\service\data\ByteSink.cpp	Out of
memory.
bad allocation
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: December 15, 2006 6:52 PM
Kori,
Can you clarify which version of MapGuide you are using? This will help
identify whether some of the memory leak issues have been fixed or have not
been fixed yet in the build you are using.
Thanks,
Bruce
From:	Kori Maleski [mailto:Kori.Maleski at websoftdev.com]
Sent:	Fri 12/15/2006 6:24 PM
Cc:
memory.
The memory usage does increase slightly overtime.
Over a 45 minute time period it went from an average of 291000 to 301000 k -
that's about 2000 tiles.  It is still increasing slowly.
I will be running it over the weekend and monitor the memory usage as best I
can.
I can specify my starting tile column when I restart, so I do not have to
redo any processing when it throws the error.
Thanks Walt,
Cheers,
Kori
  _____
From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Sent: December 15, 2006 4:19 PM
Does the server memory usage slowly increase with time?  What is it after
generating 1000 / 2000 / 3000 tiles?  If you're generating tiles
sequentially the memory should remain relatively flat.  I wouldn't be
surprised if there are still some leaks we have to track down.
Walt
  _____
Sent: Saturday, December 16, 2006 1:12 AM
Upped the page file size.  Hopefully that is the issue.
Cheers,
  _____
Sent: December 15, 2006 11:05 AM
Here is the stack trace on that:
<2006-12-15T05:10:54>                          Administrator
 StackTrace:
        Out of memory.
        bad allocation
 StackTrace:
Out of memory.
bad allocation
        bad allocation
 StackTrace:
c:\build_tux_area\mgdev\common\service\data\ByteSink.cpp      Out of memory.
bad allocation
  _____
 <http://www.websoftdev.com/>
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
kori.maleski at websoftdev.com
  _____
  _____
Sent: December 15, 2006 10:29 AM
Subject: [mapguide-users] MgException - MgOutofMememory - Out of memory.
Hi all,
I am in the process of error trapping a tiling process in an application
using the MgTileService Class.
I am sequentially executing the GetTile function over a long duration.
I am encountering a "Out of memory." Error after 3.5 hours of processing
time on trial runs.
During each trial:
-          The error occurred after the same length of time
-          5000 to 7000 tiles have been retrieved (the difference I am
assuming being a result of the variance in the amount of features required
to build the tile)
-          the last file being written is 0 kb ( I am assuming it was opened
for writing as the error occurred)
-          the MapGuide Server service was running but non-responsive and
had to be restarted
Is this error a result of the following:
-          file I/O write issue?
-          too many tile requests in the queue or being made too often?
-          Something specific to the RAM on the machine I am running the
process on?
Is there a way to trap this and recover?
Anybody have any recommendations?
Cheers,
  _____
Kori Maleski
F: (530) 759-0923
  _____
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
