[mapguide-users] Re: wgs84 degrees to x,y
Andy Morsell
amorsell at spatialgis.com
Tue Dec 19 15:18:57 EST 2006
There is no single formula since it depends on the coordinate system that
you need to transform the latitude longitude to. Take a look in the API
help documentation at the MgCoordinateSystemTransform class for information
on this. There is some PHP sample code that should get you going under the
MgCoordinateSystemTransform::Transform function.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
From: Camilo Aguilar [mailto:camilo.aguilar at gmail.com]
Sent: Tuesday, December 19, 2006 12:00 PM
Subject: [mapguide-users] Re: wgs84 degrees to x,y
I need the formula please
On 12/19/06, Camilo Aguilar <camilo.aguilar at gmail.com> wrote:
hi, i need converter from degrees in wgs84 to plain points X, Y in meters.
does anybody help me please
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061219/ed06c7cc/attachment.html
More information about the Mapguide_users
