[mapguide-users] Re: wgs84 degrees to x,y
Camilo Aguilar
camilo.aguilar at gmail.com
Wed Dec 20 10:13:41 EST 2006
Thank you Brad , I will check it
On 12/20/06, Brad Nesom <kidsmake6 at msn.com> wrote:
> If you sign up for the free training at…
> *Working with Map Projections and Coordinate Systems in ArcGIS*
> I thought you might be interested in Working with Map Projections and
> Coordinate Systems in ArcGIS. Check out the Training Seminar description at
> http://training.esri.com/acb2000/showdetl.cfm?DID=6&Product_ID=826
> It should help with your question.
> Brad
> *From:* Camilo Aguilar [mailto:camilo.aguilar at gmail.com]
> *Sent:* Tuesday, December 19, 2006 3:25 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Re: wgs84 degrees to x,y
> Thanks for yours fast answers !,
> I am newbie in Geographic concepts , sorry and thanks for explain me.
> In response to the answer, I think that is : Non-Earth (meters)
> On 12/19/06, *Traian Stanev *<traian.stanev at autodesk.com> wrote:
> X,Y in which coordinate system?
> *Sent:* Tuesday, December 19, 2006 3:00 PM
> *Subject:* [mapguide-users] Re: wgs84 degrees to x,y
> I need the formula please
> On 12/19/06, *Camilo Aguilar* <camilo.aguilar at gmail.com> wrote:
> hi, i need converter from degrees in wgs84 to plain points X, Y in meters.
> does anybody help me please
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061220/66920af7/attachment.html
More information about the Mapguide_users
