[mapguide-users] Re: wgs84 degrees to x,y
Tony Tang tony.tang at autodesk.com
Wed Dec 20 11:18:00 EST 2006
I assume the Non-Earth (meters) that you mentioned is some kind of free
form system.
You do not care whether the feature object is geo-referenced or not.
MapGuide can treat the data in an "Arbitrary X-Y" Coordinate system
without change the (longitude and latitude) value.
Here is an example in PHP for the conversion from WGS84 to another
coordinate system.
The output of the example is:
(15, 32) to (15, 32)
Unit: Meter
You can change the $wktProj to different coordinate systems if you know
the WKT String.
<?php
include('C:\Program
Files\Autodesk\MapGuideEnterprise2007\WebServerExtensions\www\mapviewerp
hp\Constants.php');
Example_1();
function Example_1()
    $wktProj = 'LOCAL_CS [ "Non-Earth (Meter)", LOCAL_DATUM ["Local
Datum", 0], UNIT ["Meter", 1.0], AXIS ["X", EAST], AXIS["Y", NORTH]]';
    $coordSysFactory = new MgCoordinateSystemFactory();
    $coordSysProj = $coordSysFactory->Create($wktProj);
    $lat = 32;
    $lon = 15;
    $geometryFactory = new MgGeometryFactory();
    $coordinate = $geometryFactory->CreateCoordinateXY($lon, $lat);
    $convertedCoordinate =
$coordSysProj->ConvertFromLonLat($coordinate);
    $xConv = $convertedCoordinate->GetX();
    $yConv = $convertedCoordinate->GetY();
    echo  "($lon, $lat) to ($xConv, $yConv) <br>";
    $unit = $coordSysProj->GetUnits();
    echo  "Unit: $unit <br>";
  _____
From: Camilo Aguilar [mailto:camilo.aguilar at gmail.com]
Sent: Tuesday, December 19, 2006 3:25 PM
Subject: Re: [mapguide-users] Re: wgs84 degrees to x,y
Thanks for yours fast answers !,
I am newbie in Geographic concepts , sorry and thanks for explain me.
In response to the answer, I think that is : Non-Earth (meters)
On 12/19/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
X,Y in which coordinate system?
  _____
Sent: Tuesday, December 19, 2006 3:00 PM
Subject: [mapguide-users] Re: wgs84 degrees to x,y
I need the formula please
On 12/19/06, Camilo Aguilar <camilo.aguilar at gmail.com> wrote:
hi, i need converter from degrees in wgs84 to plain points X, Y in
meters. does anybody help me please
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061220/bc910a29/attachment.html
More information about the Mapguide_users mailing list
