Sorry, I am having some difficulty theming a layer
kenny at keniginc.com
Sat Jul 1 22:43:54 EDT 2006
dear list (hi again)
I have been trying now for an entire day to create themes for a point layer.
I am using the studio.
Table name is SewerDump
there are several column names but of interest are lat, lon, and type:
I used odbc to create a connection to an access db using.
Here is the process I tried to follow:
Click on Theme,
Click on Add Rule,
Click on "Condition" tab,
On the ensuing dialog box, I click on Builder,
Click on Property radio button,
select a column name called type
On "Condidion and Value", I select = (the equal sign) and then type
the value Other (this is one of many values).
I click the "Get" button and I get following error:
"An exception occurred in FDO component
Identity property must be member of property collection"
I have no idea what this mean. Every research I have done on this has
turned up nothing.
Can you please assist?
Then I
More information about the Mapguide_users
